Help Need Info
i know its been discussed b4 but is welding ur crank neccesary my local shop dooshbag know it all said its no if it goes bad u just throw it away cuz they r so easy to change ive rebuilt my top end b4 and tore my shee to the frame but never had the cases apart so id like to know can any1 out there help mei dont want mine to separate but i dont wanna do anything unnesscesary thanx in advance
With that info, no I wouldnt be concerned with getting it welded. I would want to know EXACTLY what size dome you are running and what EXACTLY your compression is. Remember, the higher your compression is the more likely you will have crank problems.
