Rodeoranger Posted March 3, 2004 Report Share Posted March 3, 2004 Ok.. I have a set of Paul Turner pipes and need to kow where I can get gaskets for them. I had somebody tell me that on the older pipes they have no gasket...They said to used heat rated gasket sealer???Is this true?? Quote Link to comment Share on other sites More sharing options...
Stuff Posted March 3, 2004 Report Share Posted March 3, 2004 I just installed a set of PTRs not too long ago... Where the pipes attach to the cylinder exhaust ports there is a rubber o-ring that fits in a groove in the header flange. I'm not sure but you may be able to get the o-rings at a hardware store...just make sure they can handle high-temps. Where the pipes connect to the silencers I used the aluminum exhaust clamps that Duncan sells. They are just a high-temp rubber hose where the aluminum clamps slide over the rubber hose and seal the pipes together. You can find these at duncanracing.com or any other atv parts supplier... Quote Link to comment Share on other sites More sharing options...
Lepew Posted March 3, 2004 Report Share Posted March 3, 2004 Yes it is true. You just use a high temp silicone sealer and slide the pipe on the cylinder. I prefer the black high temp, it isn't as noticable. I have 1992 paul turners. The newer Paul Turners now have a groove for a stock oring but I still would use high temp silicone with those to. Quote Link to comment Share on other sites More sharing options...
Lepew Posted March 3, 2004 Report Share Posted March 3, 2004 The newer Paul Turners now have a groove for a stock oring but I still would use high temp silicone with those to. With the O-ring Quote Link to comment Share on other sites More sharing options...
Rodeoranger Posted March 4, 2004 Author Report Share Posted March 4, 2004 Great thanks, will 400' degree Silicone be enoughz?? Quote Link to comment Share on other sites More sharing options...
Lepew Posted March 4, 2004 Report Share Posted March 4, 2004 Yes that should work. Everyone has their favorite. Quote Link to comment Share on other sites More sharing options...
