Noss Head Question
great glad to help..and i think you'll find david at noss a great guy to buy banshee goodies from......if you have any problem he will jump through hoops to see your taken care of......follow the torque pattern on your stock head and use some good clean grease on the orings when you install them, go around your head ten times if need be with a smaller ratchet that doesnt have a lot of leverage and just snug it up before just torqueing each nut to 20 pounds, and that head will never leak, he machines them real nice......
I talked to dave he said 21cc to be safe. I ordered it already  :D . Will I see a difference in power?
Mainly torque on the lower to mid rpm range. It made my technical hill climbs much easier because a lot of times when I would have had to feather the clutch and spin the wheels before now I can just use the throttle, not spin the wheels, and accelerate untill I hit the band. It makes it feel smoother going into the band because it pulls harder down low before the band kicks in. Theres probably more power all around but it is hard to tell because the power is smoother from the torque. A lot of difference in cooling though, makes it alot harder to overheat.
