Carb Dumping Gas
Did you take the bottom of the bowl off? When I took mine off to change the pilot the float pin fell off and the entire float essembly fell apart, then when I put it back on I didnt realize that the valve had fell out too and it was dumping fuel also.
I have the same carbs and the same problem. However, I know that in my case it is because the fuel line from the tee to the carbs is too big. I had zip-tied the fuel lines to the carb itself and that worked for a little while. But sooner or later the fuel line loosens up and fuel leaks out of the overflow line. There is still some fuel that leaks out of the line to the carbs, but it's nowhere near the volume of fuel comming out of the overflow. If anybody has a decent solution to this problem, i would be open to suggestions, later,
thebloker
I have the same problem on my stock set up carbs. I took apart the carbs and inspected, adjusted floats and still leak bad out of both carb overflow hoses since the day i bought the shee new from dealer. Is there something other than dirty carb causing this. I have to shut fuel off we not riding or i'll find one hell of a puddle under quad with in a few days. I'm thinking gas tank bigger than earlier shees and gas flow too strong?? I have no clue?? been one of my longest unsolved mysterys lol PLEASE SOMEONE SOLVE IT FOR US haha. :D
Sticky needle valve? In all reality I'm new to Banshee carbs but the one on my old Tecate used to leak like mad! It was a worn out needle valve. Float level was set perfectly but the valve would never seat properly and it would just leak leak leak.
