mybadbanshee Posted February 29, 2004 Report Share Posted February 29, 2004 My clutch feels like I broke something inside the case but I cant figure out what it is.Everything visually checked out ok but it feels like nothing is there.The lever on the case moves about a 1/4 inch up and down.I am not familiar with the internals.Any suggestions?Please help. Quote Link to comment Share on other sites More sharing options...
sredish Posted February 29, 2004 Report Share Posted February 29, 2004 My clutch feels like I broke something well fix it... take the cover off of the clutch housing and take a peek inside and see if something has in fact broke. You might need a new clutch set, which will come with the springs and all. Quote Link to comment Share on other sites More sharing options...
mybadbanshee Posted February 29, 2004 Author Report Share Posted February 29, 2004 It dosnt seem to be in the clutch pac.I put a Hinson clutch in it the middle of last season.It feels like a clip or something came off.I still get power to the wheels.Is there a clip on the bottom of the lever that is on the case? Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted February 29, 2004 Report Share Posted February 29, 2004 well, the only clip is the clip that holds the cable to the case. If that's broke you won't get very good clutch action. If the lever has play, you need to adjust it by the clutch perch adjuster or if it's real bad youneed to spit the side case open and adjust it from the pressure plate on the clutch assy itself. The little tang off the end of the actuator or clutch arm that's on the upper case where the cable attaches should point to the indide egde if the data plate on the motor, where the serial number is 2GU- Yada yada or 3gu depebding on the year. At that position, the clutch is set right. Quote Link to comment Share on other sites More sharing options...
mybadbanshee Posted February 29, 2004 Author Report Share Posted February 29, 2004 Its definatly not an adjustment issue.Its gotta be something in the case but i was hoping to fix it without splitting the case.well it dosnt look like that is going to happen.The damn thing worked fine yesterday.I dont know what the hell could have happend. Quote Link to comment Share on other sites More sharing options...
sandman121383 Posted March 1, 2004 Report Share Posted March 1, 2004 i didn't read everything here but check this post out it might be helpful. if ur ball and rod are welded u gotta split the cases to get them out IF a magnet won't do the trick. good luck and let us know if u need anything else. http://www.bansheehq.com/forums/index.php?showtopic=23551 Quote Link to comment Share on other sites More sharing options...
