TheBansheeMan86 Posted February 29, 2004 Report Share Posted February 29, 2004 i plan on extending my own swingarm and was wondering if anyone had any tips or tricks on how to do it best. i plan on doin 4" longer, and will have new chain/sprockets and a brake line (even though 4" doesnt need one) i have access to a metals shop, i'll be MIG'ing it, and also what grade/size steel to use? anyway, any tips would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 29, 2004 Report Share Posted February 29, 2004 i just extended my brothers swingarm 3 inches. i went to the local metal yard and bought some steel the same size as the factory side rails. i think it was 1 1/8" x 2". then i cut the swingarm right behind the rear cross brace. make sure when you cut these that the carrier is still on. i never took it out the whole time i extended the swingarm. it makes everything stay straighter. cut the 3" extensions and tacked them in. once you make sure everything is straight you can weld it all up. i recommend some more bracing as just adding those is doesnt make it very strong. i will get some pictures up here in just a little while for you. Quote Link to comment Share on other sites More sharing options...
dnhyoung Posted February 29, 2004 Report Share Posted February 29, 2004 I ran acrossed this site thoe other day. it has a step-by-step direction son how to entend your swingarm with photos. Here's the link: http://www.westcoastatv.com/Technical/Swin...swingarmext.htm Hope this helps Quote Link to comment Share on other sites More sharing options...
TheBansheeMan86 Posted February 29, 2004 Author Report Share Posted February 29, 2004 yeah that helps a lot! thanks guys. also, does anyone know what size (length) chain i will need for 4" over? with 13/44 gearing... i was just gonna get a 120 link then cut it down, but it would be nice to know ahead of time Quote Link to comment Share on other sites More sharing options...
