Single Rib Front Vrs Double Rib Sand Tires
oldturtle
Is there any noticable performance difference between the GBC Dune Tracker single rib front and the ITP Sandstar dual rib front. Just from appearance, the Dune Tracker looks more durable because the single rib is bigger than the two smaller ribs on Sandstar. Is this true?
And what about the GBC Shark Fin non-continuous single rib. Any advantages?
Need a little education before getting my first sand tires. Answer to this question may help me deceide what brand of "V" style rear paddle to buy and from whom. May get all 4 tires/wheels from same place and the same brand.
I couldn't tell you the differences between the tires you mentioned, but I can give you my opinion of the Sand Stars. They rock. Plain and simple. Great all around dune tires for the banshee. I wouldn't worry too much about durability, sand tires last forever.
The front and rear sandstar tire set is by far the best general dune set up I have ever ran. The rear tires are great, tremendous bite, easy to slide. The front tires respond quicker to steering input than other single rib front tires I have used. Bottom line, get the sandstars and you won't be disapointed.
Yeah the sand stars are definitly getting popular too because I had a set of sand star rears for 10" rims that I ordered from rockey Mountain knowing that they were on back order and waited for 1 month. Finally I got sick of waiting and went to the 9" rim size just because they had them in stock. If they are as good as most people say then they are a great value and just over $50 each for the rears. Only $330 for a full set of 4 on ITP T-9 rims. I should have them by this weekend.
  • 2 weeks later...
I got away with 185.00 for a full set with 20x9's on the back. Gotta love those little girls that work at Champion Honda! The fronts bite very well and on a steep hill I thought it was easier to whip the bike around and keep the front planted and pivot it around, get the stars
