03 ORANGE SHEE Posted February 28, 2004 Report Share Posted February 28, 2004 my shee had all the gears and internals replaced last year,now five rides later it wont shift past second. i can find neutral and first fine ,but the shifter feels NOTCHY and wont return to the middle sometimes,i pulled the cluth cover and the spring and shift star are fine,any ideas???? Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted February 28, 2004 Report Share Posted February 28, 2004 Shift drum and or shift forks? Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted February 28, 2004 Report Share Posted February 28, 2004 ive had the same ongoing problem, first i though it was the clutch as the plates were broken where those gears would be, switched it nothing, then i tore apart the bottom end to see if it was te gear forks or drum,nope, i have come to the conclusion that my thing isent grabbing my shit star notches, anyone know why? Quote Link to comment Share on other sites More sharing options...
bbluebanshee Posted February 28, 2004 Report Share Posted February 28, 2004 Put your shift shaft on a straight edge. I would bet it has a little wow to it. Replace it and it should shift fine. Mine had the exact same problem at the beginning of summer last year. Hope this helps!! too bad you already tore apart the bottom end. It is a really easy fix! i think my new shift shaft cost like 38 bucks. Quote Link to comment Share on other sites More sharing options...
03 ORANGE SHEE Posted February 28, 2004 Author Report Share Posted February 28, 2004 found the problem,the two ears that contact the shift star,wouldnt return because there the spring on the "ears" on the shaft got hooked somehow on the outer edge of one of the ears,sounds odd,but it was as easy fix!!thanks!! Quote Link to comment Share on other sites More sharing options...
