Front Tires
GSXR 1000
I live in FL. a lot of the trails are sand some are hard packed with tree roots.
My ? is what front tires do you recommend for this? The problem is when I
roll through a tite turn the front end pushes and sometimes I bounce off trees.
On my old shee I ran 19/6/10 HS mx it turned good but I could feel every bump
in the bars what do you guys recommend?I thought about the 20/6/10 but don't
know if I will still feel the bumps in the bars. any advice will be helpful
Thanks in advance
Thanks in advance
The Maxxis Front Pro is the best tire I've found. It steers great and will take the turns with stride, bounce off of anything and it seems to handle better than some of the others. Around $31 bucks a tire from RMATV. To solve the bump issue, you need a steering stabilizer.
