Ruff Ryder Posted February 27, 2004 Report Share Posted February 27, 2004 It coming from the middle of the motor on the bottom i assume..and everytime it sits..put a little puddle of oil there. Cant really see where it is coming from. Any of you guys ever have this problem? are they notorious for oil leaks? What could it be..its a pretty new quad..Nothing big i hope..it runs fine Thanks -Eric Quote Link to comment Share on other sites More sharing options...
MRMOONEY Posted February 27, 2004 Report Share Posted February 27, 2004 this may sound dumb but check the oil drain plug to make sure it is tight, i have forgotten to tighten mine up a few times. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted February 27, 2004 Report Share Posted February 27, 2004 more than likely you have the same problem I had when I changed the oil for the first time. IF you have changed the oil anyways. When I first changed the oil I removed the drain plug an dset aside, let all the oil drain out replaced the plug and re-filled with oil... Unfortunately I did not notice the small copper washer was STUCK to the case, and it fell off in the middle of draining the oil when I was not looking. No way you would really notice this since it fell inot the pan I was draining the oil into..... lol...Then even if you snug up the plug you will have a slight oil leak... if you emptied the oil pan, make sure to look for the little washer when you go to drain it. Quote Link to comment Share on other sites More sharing options...
brugal Posted February 28, 2004 Report Share Posted February 28, 2004 Did your chain come off at any time?Because if it did ,you might have cracked your case. Quote Link to comment Share on other sites More sharing options...
