sandman4free Posted February 26, 2004 Report Share Posted February 26, 2004 my wifes bike has a slight low end bog right after I hit the gas no matter what speed I am going then it cleans out. I checked the compression it's at 90#and replaced the carbs. is it time for a rebuild or should I go after something else?. Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted February 26, 2004 Report Share Posted February 26, 2004 90 lbs is low. all stock banshee's have a slight hesitation due to the restricive intake and exhaust. A bog could also mean worn reeds. Take a look. Quote Link to comment Share on other sites More sharing options...
sandman4free Posted February 27, 2004 Author Report Share Posted February 27, 2004 good ideas I knew the compression was low I just didn't want to go on a witch hunt trying to find the problem if it was only a compression issue. I have talked her into a full mod motor like mine. Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted March 1, 2004 Report Share Posted March 1, 2004 I think stock is around the 120 to 130 range don't quote though.. 90 does sound real low! Quote Link to comment Share on other sites More sharing options...
03'ScreaminShee Posted March 2, 2004 Report Share Posted March 2, 2004 90lbs does sound really low. I think banshee76179 is right about the 120 to 130lb range stock. Also, I just got my Banshee last friday and went riding this past weekend. I guess the bog would be normal because that is exactly what mine does but then it clears out. It almost feels like your riding an 80 until the powerband kicks in. Quote Link to comment Share on other sites More sharing options...
bluestreak01 Posted March 2, 2004 Report Share Posted March 2, 2004 Try changing youre pilot jets that what one does when the pilot jet is to small Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted March 4, 2004 Report Share Posted March 4, 2004 Nothing you can do with the stock carbs is going to clear that bog..it's caused by the engine's thirst for more air. it isn't getting enough. If you roll the throttle slow and smooth, there is no bog, if you pin it there is. It's restriction causing it. Aftermarket pipes and reeds will help to eliminate it along with removal of the snorkel and minor airbox mods. Quote Link to comment Share on other sites More sharing options...
theeechozen1 Posted March 4, 2004 Report Share Posted March 4, 2004 Mine bogs a bit right before the transition into the powerband. I didn't know if my jetting was spot on or if this was normal, my neighbor whos pretty good with jetting sez I should drop the needles down a spot to lean out the transition. I will try this and report back. I'm not sure if what you are describing is the same as what my bike does but it sounds the same. It tends to bog out right after you lay into it. I have toomeys, uni-pods with outterwears, 330 mains, stock needles and pilots. Quote Link to comment Share on other sites More sharing options...
sredish Posted March 4, 2004 Report Share Posted March 4, 2004 Mine bogs a bit right before the transition into the powerband. I didn't know if my jetting was spot on or if this was normal, my neighbor whos pretty good with jetting sez I should drop the needles down a spot to lean out the transition. I will try this and report back. I'm not sure if what you are describing is the same as what my bike does but it sounds the same. It tends to bog out right after you lay into it. I have toomeys, uni-pods with outterwears, 330 mains, stock needles and pilots. Unless your at a higher elevation, 3rd clip from the top/blunt end should work great, I've even got mine on the 4th and I don't really have too many mods. If it's higher than 1/4 throttle then your pilot might not do much. I'd check the needle. They're real easy to adjust so don't be afraid to richen and lean. The minimum I'd go is 3rd clip. Quote Link to comment Share on other sites More sharing options...
