bansheewizard Posted February 26, 2004 Report Share Posted February 26, 2004 ok i have 2 questions the frist on is why is sometime the kick start hard to get out. i was ridein today and when it got hot i could not get that bitch out. i had to jump it off the rest of the day and the second one is the right cylinder is not runnin right and the left it is fine its like when i am going down the road and wide open its not widing out. the right is like sputtin and the left is running rite. and its not the compression or teh plugs ,need some help ,thanks jason Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 26, 2004 Report Share Posted February 26, 2004 the kick starter deal is a pain in the ass. sometimes they get stuck and dont wanna come out because im guessing the ball wears the kick starter down, makin it hard to get out. holyman at one time was rebuilding peoples kickers for free. check with him on how to fix it. as for the engine problem, are you sure there is nothing in the carb?? have you checked to make sure its gettin gas ok? there could be something holding up the gas. thats the only reason i can think of as to why the right isnt running like the left if you say compression is ok. Quote Link to comment Share on other sites More sharing options...
stclark04 Posted February 26, 2004 Report Share Posted February 26, 2004 ur not the only one with the kicker stickin, mine used to do it all the time, sometime still does.. its a pain in the ass for sure.. Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted February 26, 2004 Report Share Posted February 26, 2004 It's a banshee thing that damn kickstarter. If water get's in it it will rust and become difficult. If it's only the right you need to check your carbs for dirt/ debris, fload adj..check the reeds.they go bad...and if you fried the rings you'll need a rebuild. Try disconecting the tors..a faulty toors will mess with the ignition and cause weird problems. Also carb syncronization might be out...check it. It could be something simple as a clogged jet. Your fuel lines could be run wrong causing the right to loose fuel. Quote Link to comment Share on other sites More sharing options...
knight_ripper Posted March 8, 2004 Report Share Posted March 8, 2004 I have to kick mine with the heel of my boot while pulling on it. The kickstarter on Banshee's is probably the one thing they need to replace for good. I am on my second one. You can purchase the rebuild kits for 10-15 bucks from Rocky Mountain or Chaparral. But, I am on my second one of those as well. I am about to go get a new one alltogether cause Im sick of kickin my engine, and rappin my knuckles. Quote Link to comment Share on other sites More sharing options...
