bansheeigo Posted February 24, 2004 Report Share Posted February 24, 2004 I was wondering if a timing plate & a degree key do the same thing? and if i put on a timing plate on my shee do i leave the stock degree key on? Also can anybody tell me what size of fuel line does a shee uses? thanks for your answers. Quote Link to comment Share on other sites More sharing options...
Meat Posted February 24, 2004 Report Share Posted February 24, 2004 I was wondering if a timing plate & a degree key do the same thing? Yes and no. They both advance your ignition timing. The difference between em is a "degree key" can only adjust the timing to a set number IE +4 advance or +7 adv. On the other hand, the "timing plate" is fully adjustable, meaning you can set your timing anywhere from -10(retard ) to +10(advance). If i put on a timing plate on my shee do i leave the stock degree key on? Yep. Leave the stock keyway in. You could use a "degree key" with a timing plate, but its not recommened. If you use a +4 degree key, and then set your "adjustable timing plate" to +6..... your timing would be advanced 10 degrees(+10). Also can anybody tell me what size of fuel line does a shee uses? That I dont know the answer to Quote Link to comment Share on other sites More sharing options...
yamaha350 Posted February 25, 2004 Report Share Posted February 25, 2004 the degree key usually shear off. i would spend the extra money and go with a plate. Quote Link to comment Share on other sites More sharing options...
Meat Posted February 25, 2004 Report Share Posted February 25, 2004 A properly installed degree key will not shear off. The keyway only idexes the flywheel to the crankshaft. The only way a key will shear is if the flywheel shears it off..... and the only way the flywheel will shear off a key is because it was not properly installed. The flywheel nut needs to be torqued to 60 ft-lbs. The only other possible way I can think off shearin off a degree key, is if.. the key has a physical defect. Quote Link to comment Share on other sites More sharing options...
Ducman Posted February 25, 2004 Report Share Posted February 25, 2004 The adjustable timing plate costs like $45 and the degree key costs like $10 but the advance plate it easier to install and can be easily adjusted. Quote Link to comment Share on other sites More sharing options...
