Axle- Slightly Bent After Accident
robinson373
I bent the stock axle on my shee this weekend and am not sure if I could have it straightened or not. Has anyone had this done? It I can't, what brand have you guys had the most luck with and what length? I usually ride in the sand but have recently started riding some tracks.
i bent the one on my old ex before i had a shee and once you bend somethhing its not the same ne more..i say try it and see but moybe your better off getting a new one.,...unless your tight on money..but maybve try to bend it back then see how it holds up and go from there
thanks
shane
I took the tire off and turned the axle and it was probably about an inch out of round. I am not sure that it could even be straightened. I am short on money since my banshee just ate $1200 last month but it looks like i should buy an aftermarket.
Do you guys think that wider would be better, and if so, how much wider?
Thanks for the responses
I'll chime in too. I have a durablue x33 adjustable width axle, have'nt had any problems with it. You can't go wrong with any aftermarket axle, they're all an upgrade from stock. If funds are limited, perhaps buy a used stocker in good shape, try the for sale / wanted sections here, or ebay and I'm sure you'll find something.
