That cant be the hole for the choke because I know where that one is. It is right below the smaller hole, but on the surface you cant see in the pic. I do need to buy new chokes for them. I would just email the guy and ask him what it is but his email doesnt work. So far I have ruled out the choke and air/fuel mixture screw, so what else could it be? Blueduece- so your saying I am going to need to get some kind of a connection that will T of my fuel line?
yes sir i think you will, to feed 2 carbs from one source you'll need a "TEE".....might cost ya 30cents? at a hardware store, the stock tubing might work but wont send near the fuel to the carbs, i kinda like the clear hose with the filter, just zip tie the connections or use those little baby hose clamps, if you really wanted to get tricky you could shit can the stock in tank filter and tap the whole in the reserve side of your petcock bigger by a 16th, then ride with your bike on reserve, and fuel flow will never be a issue, but then make sure you run a "inline" filter
this whole pic posting thing is a little whacky if you ask me, its so hit and miss
I agree it's very bothersome not being able to see pictures.
i use photoshop to size the pic under 50k and make sure its in jpeg format and have been able to do away with that imagestation nonsense....fox's first pic posted ok....
