Clutch Oil And Water Mess
vmaxup
Mant times I have had too pull clutch covers off the banshees. And you have that mess of water and oil falling all over the floor.
So last weekend I could not believe I did not spill a drop.
I changed my clutch.
Tipped the shee on the side(turn your gas off)
took off the radiator hose to the clutch cover and tied it up.
Then took off the clutch cover and lost no oil. just a couple drops of water that I sooked up around the water pump.
Put the new clutch in and put the covers back on and the hose.
Tipped it on its wheels and away I went.
Now I do suggest changing your oil with a new clutch.
I just was in an area were I didnt want too spill oil all over the ground. And I had no more tranny oil left.
:D
i had it tipped so the bars were on a small block of wood. Had no problem.
abott 3 drops of collant were sitting in the cases from the tube between the water pump.{the one with the o ring on it} The water never mixed with the oil it just sat in this little channel and i mopped it up with a rag no problem.
