lectro Posted February 21, 2004 Report Share Posted February 21, 2004 Well im not getting the same compression as im getting out of one pipe everything is stock... one pipe is shooting out slowly a brown liquid wich is gas water and oil ??? i already know i need new plugs but can i drain my gas? well that do it what the hell is going on? why am i not getting the same compression out the other pipe? could it be so much condinsation or what? Quote Link to comment Share on other sites More sharing options...
tithead Posted February 21, 2004 Report Share Posted February 21, 2004 there is a chance it could be condensation but i would check the piston rings. take the head off and cheack they are ok and all in 1 peice. Quote Link to comment Share on other sites More sharing options...
lian Posted February 21, 2004 Report Share Posted February 21, 2004 around winter when i wasnt using mine much i had sort of white crap come out and ran terible i was afriad to rev it and start it up but that fixed it its most likly condensation Quote Link to comment Share on other sites More sharing options...
tithead Posted February 21, 2004 Report Share Posted February 21, 2004 it could also be a knackered gasket. it could be fucked on the cylinder that the compression is week Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted February 21, 2004 Report Share Posted February 21, 2004 it could also be a knackered gasket. it could be fucked on the cylinder that the compression is week what ever that is. I sure would hope it's not that. Quote Link to comment Share on other sites More sharing options...
boonman Posted February 23, 2004 Report Share Posted February 23, 2004 I hope my gasket never gets knackered....... And you need to search if you are loosing coolant or gear oil. Does the bike smoke bad? I don't quite understand where you are going with your post? You know you need new plugs, and you haven't replaced them? Why not? If you have a fouled plug, you won't get much air being pushed out of the pipe. That's what i think you mean by "compression". You may have just fouled the plugs....... Quote Link to comment Share on other sites More sharing options...
