Banshee Bull Posted February 21, 2004 Report Posted February 21, 2004 I just bought this 96 from a guy here in the Texas Panhandle for "altitude reasons" I checked the compression and it has 115 on both cylenders, it has Paul Turner mid range pipes, k&n inbox filter & a twist throttle w/o TORS tops & no idle screws were put in the sides of the carb. and its has 290's for jets on the mains. Smokes real bad and fouls plugs also Quote
Holyman Posted February 21, 2004 Report Posted February 21, 2004 Drain out all the gas, put in new plugs and mix to a reasonable ratio. Probably just bad gas mixed too rich. I'll send you a sample of Amsoil if you don't already use a premix that you like. And WELCOME to Banshee HQ. IHRbearings@peoplepc.com Quote
Banchetta Posted February 24, 2004 Report Posted February 24, 2004 I agree w/ Holyman....I'd also check to see what size pilots you have... Quote
