screamingtwin Posted February 19, 2004 Report Share Posted February 19, 2004 I have a 2001 banshee with FMF fatty pipes and maxxis razr rear tires. I have little money and need to know what is the first thing to change for motocross? Any answers will be appreciated. Thank You Quote Link to comment Share on other sites More sharing options...
sredish Posted February 19, 2004 Report Share Posted February 19, 2004 Easy. Plain and simple. Suspension. You can go faster with a stock quad with trick suspension, than a tricked quad with stock suspension. You got some good mx pipes to move a little. Now get some shocks and a-arms and a wider, stronger rear axle to glide you around the curves. Your stock axle can only handle so much mx, or you'll be buying a new one anyway, after you've spent your dough. Then, look into porting, and carbs and stroker kits and on and on. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted February 19, 2004 Report Share Posted February 19, 2004 Easy. Plain and simple. Suspension Agreed. Quote Link to comment Share on other sites More sharing options...
screamingtwin Posted February 20, 2004 Author Report Share Posted February 20, 2004 Anybody else? Quote Link to comment Share on other sites More sharing options...
fixitrod Posted February 20, 2004 Report Share Posted February 20, 2004 Bump the compression, lighter flywheel, suspension!! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 20, 2004 Report Share Posted February 20, 2004 Easy. Plain and simple. Suspension Agreed. also agree. you can have a ton of power, but if you cant get it to the ground in the corners and shit, what good is it? Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted February 20, 2004 Report Share Posted February 20, 2004 get some wider aarms and shocks quicksand motorsports has really nice aarms shorter swing arms help turning too and traction Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted February 20, 2004 Report Share Posted February 20, 2004 im with everyone here, shorter swinarm and suspension to get that power to the ground! you have more power then 4 strokes, now u just have to get the frame/suspension set up like one Quote Link to comment Share on other sites More sharing options...
