Hydraulic Clutch Install?
highroller
it should go on without a problem. mine went right on and worked perfectly. what do you mean it wont install like the stock cable? on the clutch arem you have to take off the spring. then slip the end of the hydraulic clutch in the arm. then there is a bracket that goes over the top of the slave cylinder that screws into the top of the engine. i never had any problems with mine, if you dont get it let me know and ill get some pictures of my brothers.
