sheestofast Posted March 4, 2004 Report Share Posted March 4, 2004 Doesnt it leave white scratches, the sand paper?, thats the only thing im worried about or i would also have mine cut already. Quote Link to comment Share on other sites More sharing options...
evil Posted March 4, 2004 Report Share Posted March 4, 2004 you have to use fine sand paper to smooth it out. Quote Link to comment Share on other sites More sharing options...
thegreatestever Posted May 8, 2004 Report Share Posted May 8, 2004 Iam about to cut my fenders What is the best way to cut the front fenders? Any pics would be a good help. Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted May 8, 2004 Report Share Posted May 8, 2004 Get an extra set of fenders in case you go muddin if you dont want to get wet Quote Link to comment Share on other sites More sharing options...
k10355ss Posted May 9, 2004 Author Report Share Posted May 9, 2004 like i said i used a hacksaw and a razor blade....i think they're worthless...i havent got hit with any rocks yet ...i get a tad bit more mud in the face but thats why goggles were invented....they look way better cut even if its a stock bike Quote Link to comment Share on other sites More sharing options...
evil Posted May 13, 2004 Report Share Posted May 13, 2004 also after you cut them you can sand them, then hit it with a heat gun to make the fine white marks come out of the cut. looks smooth as ice when its done. Quote Link to comment Share on other sites More sharing options...
phonebem Posted May 13, 2004 Report Share Posted May 13, 2004 You could also fab some brackets to re-atach your front fenders to the quad. It works best if you cut them at the body line where the fender curves up and away from the tank. Bend some flat stock steel or aluminum to match the angle and drill holes to match the bolts for the front bodywork and through the fenders to attach the brackets too. When you do it right all you have todo to re-attach your fenders is to back out the bolts that hold the fender at either side of the tank, slide the bracket back in, screw the bolts back in, re-attach the fender supports to the frame (they can be left attached to the fenders). It only takes like 5 minutes to have fenders again. I'll try to get some pics soon to better describe what I'm saying. Quote Link to comment Share on other sites More sharing options...
