Loose Axle
Nutz
I have a 2002 Shee with a loose axle. When the weight is off the rear end you can move the axle back and forth and up and down, maybe 1/16 to 1/8 inch or so. To me it feels like some slop with the bearings or I just cant get the axle nuts tight enough. Any advise would be nice before I tear into the beast for a overhaul.........Thanks Brian
ok listen up,tip,on the inside nut pu a bit of teflon grease on,makes tightening up eisier and on outside nut a little loctite,lateron u can easily retighten the nut with less force if u need to. i swear by this teflon stuff,i use it on everything,if u need it a little thinner,just add a little bit of oil to it and u can make it to whatever consistancy u want.is very good a little bit thinned for assembling engines on critical parts such as cams and cranks,bores ect,makes the first start up a bit more freindly for the motor.
