So when I have my bike idleing and you give it gas quickly, it bogs then it will rev fine, I have sst pipes, a k&n, with umi adaptor, no lid, a 300 main, and the needle lifted one notch.(so I lowered the clip) and the air fuel screw at 2 turns out..
put the clip back to stock, and try a 27.5 pilot like spoin mentioned and a 290 main. another thing, whats the sea level where you live ?
Your too lean on the air screws.....Try .5 turn out from seated.....Lean will make it hesitate, if the air screws improve a lot, then try a 27.5 pilot. My friends shee didn't like the 27.5, but yours might....leave the needle position..
What are you scared of???? You won't know unless you try it, it won't hurt anything, but could help you out a lot...... <_<
