roadrash Posted February 12, 2004 Report Share Posted February 12, 2004 I have a problem with my carbs i believe. My quad will only start when up on the tail, the gas floods the airbox and boom its starts first kick... But when on all four wheels nothing unless u add fuel to the cylinder manually? anyone got an idea whats going on???? also i have taken the stock TORS off but it ran fine before. Quote Link to comment Share on other sites More sharing options...
boonman Posted February 12, 2004 Report Share Posted February 12, 2004 Have you disconnected the TORS brain module? Also, are the slides in the proper carb so that the cutaway faces the airbox? I can't see how physically you could start the bike with it on end, you would fall off? Are the float bowls on the proper carb? THere is a left and a right. The left bowl has 2 brass tubes, the right bowl has 1. Are you using the choke? Quote Link to comment Share on other sites More sharing options...
