Dyna Fs Digital Performance Ignition
what exactly does DYNA FS digital performance ignition do? does it make huge differences? my shee came with the DYNA FS so i dont know what it was like before it but i read in an eairler post about top speeds and there is no way mine is that slow...it might be because of the DYNA FS which is why i wanted to know about it. thanks
I have the Dyna on mine, and I love it. It has four preprogrammed curves for anything from stock to top end. It produces a hotter spark than a stock box.
Top speed charts don't mean anything. It's just a guide, and will differ depending on who created it. The Dyna ignition is WAY better than a stock box. If you want to know your top speed, get someone with a radar gun or GPS system.
Peace
The Dyna ignition will adjust timing according to a preset curve to gain the best performance. It would provide similar results to advancing the timing using a timing plate. However, with one big difference, it is designed and tested to advance in certain areas and different degrees to provide optimum performance. You wouldn't want to run the ignition with a plate that was advanced. You can also design your own timing curve and load it into the ignition to provide customized performance.
  • 2 years later...
i bought the fs ignition and was wondering what each curves are for. what i bought it during the winter and lost my sheet. i was looking for a little help. i did a search on it and could not get any resolts thanks for the help
