tacoking Posted February 11, 2004 Report Share Posted February 11, 2004 My shee keeps overheating. I am thinking its the waterpump but I haven't check it yet. I have a 1.6 rad cap and noss head. Its jetted correctly according to fmfs website and the altitude and temp I ride in. It keeps spiting out fluid from the over flow even on short rides with no elevation changes. After riding the radiator is hot up top but the botttom portion of the radiator is cool, as well as the bottom hose. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
Schizo Posted February 11, 2004 Report Share Posted February 11, 2004 I would check the jetting first of all because a lean jetting will certainly overheat. Just because fmf's site tells you what size jets to run dont mean that it's jetted properly, do a wide open throttle plug check and if it's not a jetting issue then tear into the water pump. Quote Link to comment Share on other sites More sharing options...
bkabina Posted February 11, 2004 Report Share Posted February 11, 2004 You may have an air lock,not letting the water circulate. Quote Link to comment Share on other sites More sharing options...
Ducman Posted February 11, 2004 Report Share Posted February 11, 2004 My shee keeps overheating. I am thinking its the waterpump but I haven't check it yet. I have a 1.6 rad cap and noss head. Its jetted correctly according to fmfs website and the altitude and temp I ride in. It keeps spiting out fluid from the over flow even on short rides with no elevation changes. After riding the radiator is hot up top but the botttom portion of the radiator is cool, as well as the bottom hose. Any help is appreciated. I think you may be correct on the waterpump if the radiator feels realy cool at the bottom. It will naturally be cooler at the bottom but shouldn't be cool to the touch when the top is really hot. Sounds like a really low flow comming out of the pump. Just a guess, it could be from cavatation if you have a bad air leak in front of the pump or a realy screwed up old plastic impeller with some busted fins? Quote Link to comment Share on other sites More sharing options...
