How To Build A Leak Down Tester
chase73
Hey all I just blew the top end on my sled and the piston had a hole melted threw the top and I dont want it to happen twice there are only a couple off possability,s to why it happened. The first I have high compression domes that require atleast 92 octane and the other day I was in a bind lost and had to use shitty 87 octane fuel to get home . The second is a gasket leak ether the base or the top or maybe crank seal . I dont want to split the cases so I want to put it together and do a leak down test .I thought I saw it on the sitre somwhere and I cant fid it any help is appreciated
I took two short pieces of radiator hose from a car and fitted them with soft plugs and clamped them tight with hose clamps. They were then put over the exhaust ports on the cylinders and clamped down tight. I then got two more soft plugs that fit snugly in the boot leading to the reeds and brazed an air fitting with a one way valve in one and a pressure gauge in the other. Once these were clamped down with the original clamps I performed the leak down test and it worked perfectly. All of these items should be able to be found at an automotive store, hopefully. I had them all around the shop so I can't be sure. Just be sure you don't have a leak around your braze or one of the soft plugs. Hope this helps, or at least gives you some ideas.
thanks for the help I will put one together tommorrow to test my sled the dimensions are a little different but, the theory is exactly the same B) I am hoping its not the cranak seals i dont feel like spliting he cases.OHHHHHH p.s the imagstation is working fine its banshee hq i right clicked the messed the bad pic and got the properties address and justs went to imagstation to see picture
