Big Problem
96shee84z28
so what should my jetting be with these mods??
my mods t5s, coolhead 20cc domes, 60mm pistons, vforce reeds,toomey 2 into 1 uni filter, and a few other small things
Try checking the Toomey website for jetting recommendations. My best guess where your correct jetting would be for 60 degrees, sea level, replace air box with 2 into 1 foam filter is: #30 pilots - A/S 1.5 turns out, stock needle setting or possibly 1 clip richer, 310 mains. Your Toomey jet kit probably came with somthing like 280 or 290 mains which would be for the stock air filter with the lid on, snorkle removed. This is just an approximation, starting one or 2 sizes larger on the mains and working your way down untill it doesn't bog is the safest way to adjust jetting so you don't start lean, or if you start at 310 and it doesn't bog from being too rich do a plug chop and it will tell you if your jetting is good.
Read this to lean how to approximate jeting and how to do a plug chop:
Banshee Jetting FAQ
