wheeleymaster99 Posted February 8, 2004 Report Share Posted February 8, 2004 i put my PEP shocks on my stock a-arms today and it droped my frontend about 3 inches with the stock a-arms and i have +2s on the way so i would think that would drop it more. i know it should lower it some but that just seemed like a lot let me know what you think Thanks Quote Link to comment Share on other sites More sharing options...
bpreuss Posted February 9, 2004 Report Share Posted February 9, 2004 well are they for +2 arms or for stock? if they are zps you can up the ride height but youll hafta weight and see when you get them Quote Link to comment Share on other sites More sharing options...
wheeleymaster99 Posted February 9, 2004 Author Report Share Posted February 9, 2004 yeah i got them used and they are supposedly for +2 but how much should it lower the frontend on +2 arms compared to stock Quote Link to comment Share on other sites More sharing options...
Blue Duece Posted February 9, 2004 Report Share Posted February 9, 2004 yeah i got them used and they are supposedly for +2 but how much should it lower the frontend on +2 arms compared to stock depends on how the preload is set, you could have a soft spring with little to no preload in which case the weight of the bike would drop it 2-3 inches, then when you mount up could drop another inch or two, leaving you with very little travel and a fairly shitty acting shock......a good shock setup, the body is full of spring, not a nut cranking a light spring down 4 inches......sounds like you might want to come up a gage in springs.......fairly cheap and any good shock tech can do it for you......... Quote Link to comment Share on other sites More sharing options...
