jcanapa Posted February 8, 2004 Report Share Posted February 8, 2004 Its been a few months since I was on the HQ, been out of town. I have a problem. The motor wont start. Ive rebuilt this motor a few times so I know it inside and out but am stumpped. I pulled the carbs apart, thier fine. The fuel filter is fine. Im am at 900ft above sea level. I have 128lbs if compression. 21cc domes. I get fuel to the bowls. If I put gas in the cylinder directly it will start for a second but then die. Its something that effecting both cylinders. Does anyone have any clues as to the problem on this. Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted February 8, 2004 Report Share Posted February 8, 2004 well has it been siteen awhile, maybe the jets clogged or its just not startin with that old gas, try some new mix and see what happens Quote Link to comment Share on other sites More sharing options...
lucky13 Posted February 8, 2004 Report Share Posted February 8, 2004 IS THE T.O.R.S STILL HOOKED UP Quote Link to comment Share on other sites More sharing options...
Big Blue Posted February 8, 2004 Report Share Posted February 8, 2004 old gas, tors, hose between the carbs? Quote Link to comment Share on other sites More sharing options...
1_bansheenutt Posted February 8, 2004 Report Share Posted February 8, 2004 If mine sits for a few months, I use my other quad to pull it and getting it going, usually works well. My shee is very cold natured. In warmer weather or when the engine has been ran for a few no problems. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted February 9, 2004 Report Share Posted February 9, 2004 If mine sits for a few months, I use my other quad to pull it and getting it going, usually works well. My shee is very cold natured. In warmer weather or when the engine has been ran for a few no problems. check your compression, thats a good sign that you might be low..... Quote Link to comment Share on other sites More sharing options...
Banchetta Posted February 9, 2004 Report Share Posted February 9, 2004 Its been a few months since I was on the HQ, been out of town. I have a problem. The motor wont start. Ive rebuilt this motor a few times so I know it inside and out but am stumpped. I pulled the carbs apart, thier fine. The fuel filter is fine. Im am at 900ft above sea level. I have 128lbs if compression. 21cc domes. I get fuel to the bowls. If I put gas in the cylinder directly it will start for a second but then die. Its something that effecting both cylinders. Does anyone have any clues as to the problem on this. I agree, try some new gas, then check to make sure your getting fuel to the carbs.....pull the hose off the carb and see if gas pours out freely..if not, then the filter or petcock on the tank is plugged. If there is plenty of fuel, then clean the carbs thoroughly w/ an air compressor, I'd even put the fuel hose on and see if the floats are working properly before putting the carb bowls back on...... Quote Link to comment Share on other sites More sharing options...
