Transmission Oil
Trouble T
I use bel ray gear saver, I find it works very well ad helps give me consistant shifting. I also find it does not need to be changed as often.
But then again I don't trust ATF in my banshee...
I stay clear of additives like the Lucas stuff, from what I read although it helps the oil cling to the gears to also traps air inside the oil which is a bad thing.
Edited by Justintoxicated
