i agree with demon 350, i installed my tr6 and its great and im really happy from them and u can go and check tommey website for pics and specifications about the products.
If you intend on having motor work done like porting, then do not buy these pipes!!! they do not work well at all with a ported engine or bigger carbs. If you want a set of pipes go with CPI's
i disagree, but hey what would i know .....
I see most people on here are comparing stock pipes to toomeys......ANY pipe is a huge gain over stock....not much of a comparison.... :)
Do any dyno test on a motor with any porting and you will see that the TR6's are JUNK!! the TR5's are a far superior pipe with motor work! I am not trashing Toomeys one bit, they are a good pipe for a bolt on motor but CPI inframes are far superior.
Only on ported engines that have the port-timing changed. Porting doesn't hurt T6's at all!!!!!!!!!!It's all in some of your heads! If the port-timing is changed then they don't respond as well as the T5's or other pipes. You can add mods to a T6 and see just as much improvement as any other pipe.
