lucky13 Posted February 5, 2004 Report Share Posted February 5, 2004 I HAVE A+4MM LR STROKER MOTOR. THE CYLINDERS ARE IN THE STOCK LOCATION. I HAVE A SPACER PLATE BETWEEN THE CYLINDERS AND HEAD. I AM GOING TO PURCHACE A AFTERMARKET HEAD WITH O-RINGS. INSTEAD OF A GASKET,WILL THIS HEAD WORK ON TOP OF THE SPACER PLATE THANKS Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted February 5, 2004 Report Share Posted February 5, 2004 should work the exact same all your doing is using a oring instead of a gasket Quote Link to comment Share on other sites More sharing options...
feature000 Posted February 6, 2004 Report Share Posted February 6, 2004 I tried that and had leaks all over the place, ordered stroker domes or cut domes from shortys, but also heard that patriots racing sells them plus it looks sleeper with no plate in place. Quote Link to comment Share on other sites More sharing options...
MRMOONEY Posted February 6, 2004 Report Share Posted February 6, 2004 i can get you some custom cut domes also, let me know if you need something, i run a long rod +4mm stroker motor without a plate looks alot better in my oppion Quote Link to comment Share on other sites More sharing options...
lucky13 Posted February 7, 2004 Author Report Share Posted February 7, 2004 thanks for the information. I am going to have my 22cc domes made into stroker domes. Quote Link to comment Share on other sites More sharing options...
