If it's still fouling in one side check to make sure your compressions are the same. You may need a rebuild if they have a difference in em. Also make sure your wires are good. You could also try jetting it down a little bit.
Check your reeds, also, it still may be rich, but check the reeds on the left side, they may be worn just enough to foul out that sides plug.
bingo !!! i had the same problem, right side kept fouling out, turns out the reed was wasted.
damn, why didn't I think of that. :P
