lincster Posted February 6, 2004 Author Report Share Posted February 6, 2004 Well, it turned out to be the stator. Probably replace the flywheel with a lightened one while it is apart. Thanks for the inputs. Quote Link to comment Share on other sites More sharing options...
Aussie Quad Racer Posted February 6, 2004 Report Share Posted February 6, 2004 Just to let you know the way you tested the secondary curcuit on the coil is incorrect. You need to check the resistance in ohms between the two plug leads. The primary windings and secondary windings of the banshee coil are not joined together like general automotive coils. Quote Link to comment Share on other sites More sharing options...
lincster Posted February 6, 2004 Author Report Share Posted February 6, 2004 Thanks, I will remember that. I was just following the instructions in Clymers. Quote Link to comment Share on other sites More sharing options...
geaux 4 it Posted February 7, 2004 Report Share Posted February 7, 2004 You can ohm out the stator. Pick up coil is between: 94-140ohms Source coil is between: 13.7-20ohms Lighting coil is between: 0.26-0.38ohms Quote Link to comment Share on other sites More sharing options...
