Time Key
lian
The degree key goes away and you put the stocker back in, if you want the timing plate! The timing plate uses the pickup to advance or retard the timing, A degree key moves the flywheel to advance the timing.............. Do you have a degree key yet? or are you asking what to get?
Well if your on a budget and need to go cheap get the +4 degree key......But just to be safe you might want to carry the stock key and some tools with ya just incase it shears off on ya! ;) But if your not on a budget and can afford it then get the timing plate! Or get ahold of BDbanshee and he can modify your stock one to go to +4 degrees.
Erik
