2004LEBanshee Posted February 4, 2004 Report Share Posted February 4, 2004 That is the sound that a banshee makes when the bolt from the fly wheel comes loose. Luckly I was bearly moveing in my drive way when it started to happen. Sounding like my crank just blew up I started to take the fly wheel cover off and I saw the nut almost off the crank. So I put it back on and started it and it sounded good. I then shut it off and put it away. The problem is that I cant hold the flywheel still when turning it. So I looked through the clymer manual and noticed the tool that they used to get it off. What is it? Where can I get it? and of course How much? Also can I use lock tight on it? And is there a washer that goes on before the nut? Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted February 4, 2004 Report Share Posted February 4, 2004 Impact gun will solve your problems Quote Link to comment Share on other sites More sharing options...
eehsnab2 Posted February 4, 2004 Report Share Posted February 4, 2004 Yep, air tools!!! They're more fun anyway. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted February 4, 2004 Author Report Share Posted February 4, 2004 i'll give that a try Quote Link to comment Share on other sites More sharing options...
. Posted February 4, 2004 Report Share Posted February 4, 2004 couldnt you put it in gear and hold the rear brake down? Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted February 4, 2004 Author Report Share Posted February 4, 2004 Maybe but I was buy myself and didn't have air tools. Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted February 4, 2004 Report Share Posted February 4, 2004 yea i was thinkin put it in gear, or pop off the chain and get someone to hold the front sprocket with a big ass wrench, and when it came off did it kill your clutch lock washer Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted February 5, 2004 Author Report Share Posted February 5, 2004 It never came off just the bolt came loose. And what is a clutch lock washer and why would it kill it. Why would I hurt anything in the clutch. I probably could have sat on it held in the foot brake and pulled with my arm. Quote Link to comment Share on other sites More sharing options...
brock_fuzzy_69 Posted February 5, 2004 Report Share Posted February 5, 2004 the clutch holding tool doubles as a flywheel holder the goofy thing that looks like a pair of vice grips to hold the clutch basket otherwise you can use a spanner wrench or a rubber strap wrench on it Quote Link to comment Share on other sites More sharing options...
Leadfoot350 Posted February 5, 2004 Report Share Posted February 5, 2004 Put a copper penny inbetween the teeth on crank gear and the other gear on the right side of the motor. The copper penny is not that strong and will not harm the gears at all. Tell me if you can understand what I am saying? I am not sure if it came out right. Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted February 5, 2004 Report Share Posted February 5, 2004 the washer goes behind the nut to make sure that it doesent spin itself off, Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted February 5, 2004 Author Report Share Posted February 5, 2004 I dont think I have a washer on can I put on any washer that fits or do I need a special size? Quote Link to comment Share on other sites More sharing options...
. Posted February 5, 2004 Report Share Posted February 5, 2004 its a washer that has a tab on it that you bend over after you tighten down the nut so it cant come off Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted February 5, 2004 Author Report Share Posted February 5, 2004 Where can I get one other than dealer. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted February 5, 2004 Author Report Share Posted February 5, 2004 Never mind I called the local bike shope and they have one in stock thanks guys. I guss I must have lost it when I took it off. I dun no. Quote Link to comment Share on other sites More sharing options...
