Banshee03QC Posted February 4, 2004 Report Share Posted February 4, 2004 See my mods in my signature. What's the next mods should I do? Cool head?? V-Force?? Advance timing?? Any other things?? If it can help, most of times I ride in sand pit and I do some hill climbing. Quote Link to comment Share on other sites More sharing options...
mrmatt Posted February 4, 2004 Report Share Posted February 4, 2004 IMHO, increase compression by either having your stock head milled or purchase an aftermarket head. The increased compression helps keep the motor pulling, even when the rpms drop and it 'falls off the pipe'. Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted February 4, 2004 Report Share Posted February 4, 2004 I agree with Mr.Matt.Increase your compression.Go for an aftermarket head. Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted February 4, 2004 Report Share Posted February 4, 2004 i'd get some port work done. If you havent all read though id get some new tires first, then get a tooth bigger front sprocket. Quote Link to comment Share on other sites More sharing options...
sredish Posted February 4, 2004 Report Share Posted February 4, 2004 IMHO, increase compression by either having your stock head milled or purchase an aftermarket head. The increased compression helps keep the motor pulling, even when the rpms drop and it 'falls off the pipe'. I agree with Mr.Matt.Increase your compression.Go for an aftermarket head. I third that. The high compression head will help put your shee through the paces. I'd recommend an aftmkt, not milling. Milling is cheaper, but will help your banshee get hot, and an aftmkt might not be cooler, but the extra cooling in it will help offset the extra heat from the compression. Go Noss or Coolhead, or even Vitos. After that, carbs and porting come to mind. If you do have porting in mind, make sure you consider that when thinking of carbs. Quote Link to comment Share on other sites More sharing options...
Banshee03QC Posted February 4, 2004 Author Report Share Posted February 4, 2004 I don't want to port my engine. I have SST and it seems that SST sux with ported engine and I don't want to change my pipes. But I will check for the front sprocket. Any others things? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 4, 2004 Report Share Posted February 4, 2004 id go for an aftermarket head and v force reeds. go for a pro design or noss head. you can raise your compression with one of them and make it so that you can change it at anytime. i have v force reeds and like them. i noticed quite a difference between stock and v force. i wouldnt recommend going up in sprocket size unless you get ported and raise your compression. and also what do you do with your banshee? if you are not dragging then y bother going up in sprocket size? if you are runnin trails id say drop down a tooth. Quote Link to comment Share on other sites More sharing options...
sredish Posted February 4, 2004 Report Share Posted February 4, 2004 i wouldnt recommend going up in sprocket size unless you get ported and raise your compression. and also what do you do with your banshee? if you are not dragging then y bother going up in sprocket size? if you are runnin trails id say drop down a tooth. I don't know about dropping a tooth. I went from 14 to 13 just to try and I was spinning all the time, by the time I got traction again, it was time to shift. I've since went to a 15 front and it has made all the difference. I'd say a 15/41 or a 15/40 would be ideal for general purpose. Quote Link to comment Share on other sites More sharing options...
eehsnab2 Posted February 4, 2004 Report Share Posted February 4, 2004 Get your head milled and get out your dremel and grind your timing plate...its free! Two easy mods under $50 bucks... Then spend the rest of the money you would have spent on some v-force. Quote Link to comment Share on other sites More sharing options...
spoin39 Posted February 4, 2004 Report Share Posted February 4, 2004 Definately raise compression, either mill head or coolhead, then go with V-force reeds. It looks like we all pretty much agree on the next mods. Quote Link to comment Share on other sites More sharing options...
Phast Posted February 4, 2004 Report Share Posted February 4, 2004 1. Head milling (about .030) or aftermarket head (use 20 cc or 21cc domes) to up comp. 2. Port out those damn reed cages and get some TDR reeds 3. Clean up the cast job on the intake tracks 4. Get a timing plate and adj. to around +4 to +5 5. Make sure to jet up and check your jetting all the time 6. Just remember that a motor is a air pump and the more air you can get in there the better!!!!! Quote Link to comment Share on other sites More sharing options...
Banshee03QC Posted February 5, 2004 Author Report Share Posted February 5, 2004 Thanks a lot! I decide to buy a 20cc coolhead. I will see later for the next mod... Quote Link to comment Share on other sites More sharing options...
sredish Posted February 5, 2004 Report Share Posted February 5, 2004 Thanks a lot! I decide to buy a 20cc coolhead. I will see later for the next mod... Congrats. Good purchase. Quote Link to comment Share on other sites More sharing options...
