sand rocket Posted February 3, 2004 Report Share Posted February 3, 2004 got the shee put back together this weekend. I had some port work done that was describe as a drag port for stock carbs. So far shee is running good. I still need to get the jetting dialed in. I is kind of difficult here because of the weather. Any way the question that i have is gearing, I noticed that when i hit 3nd gear it kind of bogs. In 2nd it only spins on asphalt. think that this is jetting or gearing. I have stock gearing currently when tested. I talked the the builder and he said to go to a 15 on the front. and mabe go from 350 to 340. What to you think? Quote Link to comment Share on other sites More sharing options...
Cotton eyed Joe Posted February 3, 2004 Report Share Posted February 3, 2004 got the shee put back together this weekend. I had some port work done that was describe as a drag port for stock carbs. So far shee is running good. I still need to get the jetting dialed in. I is kind of difficult here because of the weather. Any way the question that i have is gearing, I noticed that when i hit 3nd gear it kind of bogs. In 2nd it only spins on asphalt. think that this is jetting or gearing. I have stock gearing currently when tested. I talked the the builder and he said to go to a 15 on the front. and mabe go from 350 to 340. What to you think? I've taken mine out a little here and there, and I'm running a 330 with a mild port, so maybe drop to a 340 and check it out. With the stock carbs you can only put so much in to the engine anyway. I don't know why it would be bogging on you in 3rd though. 3rd gear on mine still spins on asphalt. I think I could get 4th to if I really wanted. Quote Link to comment Share on other sites More sharing options...
