cotton133 Posted February 2, 2004 Report Share Posted February 2, 2004 I recently purchased a banshee that had not been cranked in about six months. I have gotten it running but it hates to crank when it is cold. The only way I can get it to start when it is cold is to leave the choke off, and hold the throttle about half way open. Usually when it does start to turn over, gas pours out of the right cylinder exhaust. When it finally starts to run it sounds like only the left side is running for a few seconds then it starts to run and idle fine. There are no problems if I cut it off and try to crank it again while it is warm. I am pretty sure that it is carburetor related but I don't have very much experience with them. Any ideas on what I should try to fix this? I am running the stock carbs. Quote Link to comment Share on other sites More sharing options...
1_bansheenutt Posted February 2, 2004 Report Share Posted February 2, 2004 Boy consider yourself lucky.........I have to pull start mine with another quad if its really cold outside, no problem on warm days, 1 to 2 kicks and it going! Quote Link to comment Share on other sites More sharing options...
boonman Posted February 2, 2004 Report Share Posted February 2, 2004 SOunds like the carbs need a litle attention. Make sure the left carb has 2 brass tubes in it. What is the jetting. it could be lean on the pilot jet.... Quote Link to comment Share on other sites More sharing options...
