Nitromethane
drag-350
Nitromethane is something that can be added to Methanol. It doesn't mix with gas. I am not sure on the timing, but I know you have to get much bigger jets and there have been plenty of blown motors with people toying with it. I does make lots of HP though when dialed in.
i have ran methanol for two years now. i know pretty much how it work's so i thougt i would try nirtomethane i have read a lot about it& how it can be mixed just haven't heard about what to set your timing on....and that was the first time that i have posted anything on here . sorry about that . B)
i would ask on www.planetsand.com there are a few people on there that run it and might be able to give you some info on the timing i run plus 8 with meth i don't think it would be to much off from that probably like 7 or mabey 6 to keep the motor cooler duno though
i will post it on planet sand and see if anyone can give me some info on the timing.i run my timing on 6 right now maybe all try it like it is.you said you run your timing on 8 i have heard of guys runing a higher timing . but i haven't tried anything more then 6. i will try runing mine on 8 and see if it help me on menthanol. thank's for the info B)
