Shaving Stock Head
I just got my hands on a stock head and my buddy that has a shee told me to shave the head to 30 thousands , is that right. plus i have a degree key as well but not installed yet . I have no engine mods done yet either, just stock exept for fmf gold series pipes and k&n filter , so i'm just woundering if i risk blowin the engine. so if I get this shaved what should i do to my shee so she wont go boom . thank you for the help
Shaving or milling .030 off of the head is a good mod.
If your sure the head and cylinders have never been decked
then you will not have any problems taking .030 off. It is
a good idea to check your squish clearance before running the
engine though. This can be checked with a piece of led/tin solder
inserted into the spark plug hole. Slide it in until it is against the
cylinder wall and then turn the kicker by hand and let the piston
smash the solder. Remove and mic the solder. It should not be thinner
than .022, I've heard others say .026 is minimum. Fixitrod or boonman
could tell you for sure.
What I noticed most with this mod was the ability to pull a lower gear i.e
you don't have to downshift as often to find the powerband.
DO NOT go more than .030" with your head. Very bad things will happen. The little detonation gremlins will haunt you untill catastrophic failure happens. With that much, it will happen in a very short time. Your squish if you didn't get the head re-chambered would be nothing. You would have major problems. With .030" off the head gasket surface, you will experience "0" problems. Only benefits, all the way across the board. With anything over .030", you need to have the chambers re-cut to correct the squish....
Like boonman said, if you go more than .030 you will need to have the squshband modified as well for piston clearance and for correct combustion geometry. Not very mny shops are capable of performing this. Also at more than .030 you will need to possibly run a mix of race and pump fuel or straight race fuel so you don't have a detonation problem. If you go over .030 and don't have your crank trued and welded you will trash your bottom end a lot faster too. It would be a good idea to check your compression after installing the head milled as well as checking your squish clearance.
i ran the 090 head for over a year with no problems.
You most certainly did NOT run a stock chambered head that was .090" shaved down with stock crowned pistons and stock base gaskets. :blink: I could see if you double base gasketed it or something like that. But just pulling off the head, and shaving it .090", and putting it back on, you would have caused catastrophic engine failure. Without a doubt. No way in la-la land or wherever you spend your days did you run that head..... Maybe you dreamed this up when you were in the lovely confines of the "I love me" jacket?? :o:ph34r: How many stock heads have yo looked at? You are spewing bull shit out of your sewer at this present time....
i am not stupid when it comes to banshees. i had no problems running the head. i measured the head compared it to a stock head. and then had bill from shortys racing measure it. i ran it on a drag ported .40 350. NEVER HAD A PROBLEM. also running weisco pistons.bike ran good while i had it on. most of my friends thant have stock heads run them .085
