erbilabuc Posted February 1, 2004 Report Share Posted February 1, 2004 I changed my jetting and went from a 300 main to a 290 main and from 30 pilots to 25 pilots. Banshee runs good and power kicks in when it is supposed to. The left side is hot but the right side is muchhhhh hotter. Could it be the air/fuel screws need to be adjusted? Quote Link to comment Share on other sites More sharing options...
Wallrat Posted February 1, 2004 Report Share Posted February 1, 2004 are the carbs sync'd? Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted February 1, 2004 Author Report Share Posted February 1, 2004 i just sync'd them two days ago but im gonna take a feeler gauge to it again. Do you know what the exact gap is supposed to be? Quote Link to comment Share on other sites More sharing options...
Meat Posted February 1, 2004 Report Share Posted February 1, 2004 did you have the hot pipe\hotter pipe problem before you changed your main jets ?? Its odd that you say its running great, cause first thing I think is the one carb float might be sticking. Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted February 1, 2004 Author Report Share Posted February 1, 2004 did you have the hot pipe\hotter pipe problem before you changed your main jets ?? Its odd that you say its running great, cause first thing I think is the one carb float might be sticking. no i didnt have this problem before, it happened after I jetted but it runs fine. THe difference is very obvious, On the right side I can tell it is much hotter then the left side. I was riding in the rain yesterday and the right side was completely dry but the left side had water all over it and it wasnt steaming. Quote Link to comment Share on other sites More sharing options...
sweetshee4312 Posted February 1, 2004 Report Share Posted February 1, 2004 maybe its not one side runiing hotter, maybe its the other side running colder, Quote Link to comment Share on other sites More sharing options...
Banchetta Posted February 2, 2004 Report Share Posted February 2, 2004 Does it smoke evenly?? Air screws at the same setting? I'm not sure how a feeler guage would work in a carb w/ a round bottom, I'd think it wouldn't be accurate enough, but I've never tried that so I won't say, but I usually just bottom the slide out until it barely touches, then turn them up 1 full turn.......If they are in sync, then I'd do a leakdown test to find any air leaks, could blow a motor is you have an air leak... Quote Link to comment Share on other sites More sharing options...
