got1banshee Posted January 31, 2004 Report Share Posted January 31, 2004 I have a set of lights that only have two wires on it and I wanted to put them on my banshee. My banshee has 3 wires what wire does what? How should I wire thes light up? Thanks Quote Link to comment Share on other sites More sharing options...
TheNewGuy Posted January 31, 2004 Report Share Posted January 31, 2004 i did the same thing dude...had a set of car fog lights i put on my bike... the black is the ground wire...im sure you know what that is the green and yellow are just the high and low beam wires...im not really sure which one is which but im almost sure the green is the high beam...either you can fuse the green/yellow into one and run it into a single hot wire, or you can just leave one wire hangin and connect either the green or yellow... hope this helps/makes sense Mike Quote Link to comment Share on other sites More sharing options...
Big Blue Posted January 31, 2004 Report Share Posted January 31, 2004 i think the yellow wire is high beam, green is low and black is the ground, i think that is what the instructions to my trail tech lights said. Quote Link to comment Share on other sites More sharing options...
dnhyoung Posted February 1, 2004 Report Share Posted February 1, 2004 yes, yellow is for High beam, and green is for low beam with the black being the ground. Quote Link to comment Share on other sites More sharing options...
got1banshee Posted February 1, 2004 Author Report Share Posted February 1, 2004 thanks guys!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
