I Was Woundering
ok try to follow me on this post, casue im alil drunk, i got drunk for the first time last night, im 15 whooaaa...........
Ok well i have a dynoport 2-1 pipe on my banshee right now, and i have tons of low end, but top end is a little weak, i was woundering what u think i should do, someone told me the dynoport was shit and sell it and get toomys, but i was thinking i could get liek vito super /e pistons that say they add 8hp mid and top end, and then i could get a cool head, so i have all around goood power, but i dont know weather to spend my money there, or what,
I also have a cracked case, but id rather mod my quad out
why dont you try going to 14th sprocket and see if that helps, i like the power of the PTR's and so do alot of other people, good bottom end, great mid range and decent top. Drink alot of water that will help you feel better. if you are in the market for a different set of pipes i have some t6's pm me.
The pistons alone aren't going to give you top end, they'll just help increase compression, which will help emphasize how your bikes setup. If you have low pipes and your setup for mad low end, and you increase your compression, it will help emphasize your low end.
What you need are some midrange pipes, they'll give you some low/mids and allow you to pull through the top. You'll be happy you did.
Big Blue - you have got to change your avatar, I've seen it like 5 times tonight, and it is seriously distracting. :D
