Battle Relocater
lian
when i first got my banshee it didn't have a water bottle and i got tired of the coolant dripping all over my leg and my pipes, so i got a weed eater gas tank and zip ties it to the front and haven't had any more problems, I've heard its a good ideal to move to up front too.
the bottle under your seat and between your silencers is the coolant tank and alotta people move it up front where mine is because for some reason the coolant in it will slowly go away for some reason and moving the bottle up front stops this from happening I think, alotta aftermarket companys make a water bottle relocater, hope this helps
I made mine. I suppose I could make one up for you for about $15 or you can try it before you invest if you just take the stock bottle and zip tie it to the front. Cost for that is under $1.
im going to have to move the bottle anyway and i would rather have a more permanent fix so go ahead and make me one if you dont mind.
