vmaxup Posted January 28, 2004 Report Share Posted January 28, 2004 Ok my shee runs great and I have rebuilt motors and redune many peoples Carbs. But I have this one 1996. I cant figure out. Float height is good air srew at 1 1/2 and 360 jets for Glamis. Problem If it sits for a day you cant start it no matter what. One squirt of starting fluid and it will start on the first kick and stay running, It will idle by itself all day and run great after that. You let it sit for a day and no way no start. SO easy fix find a can off starting fluid to fit in your six pack rack. So one less beer for the trip but you make it back too camp? Any ideas? I really need that extra beer at the drag or comp. Quote Link to comment Share on other sites More sharing options...
bm350 Posted January 28, 2004 Report Share Posted January 28, 2004 what size pilot jets are you running? have you pulled the carbs off and cleaned the choke tube (the one in the bowl on the left carb that feeds the choke)? Quote Link to comment Share on other sites More sharing options...
vmaxup Posted January 28, 2004 Author Report Share Posted January 28, 2004 Ill check that tube tonight when I get home. It sounds good Ill check it out and get back with you. Thanks Quote Link to comment Share on other sites More sharing options...
wheeleymaster99 Posted January 28, 2004 Report Share Posted January 28, 2004 have you tryed puttin a new set of plugs in it they may be fauled and the starting floud just cleens them off when ever you use it. just a thought Quote Link to comment Share on other sites More sharing options...
fixitrod Posted January 28, 2004 Report Share Posted January 28, 2004 Sounds like bad fuel !!!! I've had that happen before also. Quote Link to comment Share on other sites More sharing options...
vmaxup Posted January 29, 2004 Author Report Share Posted January 29, 2004 actually the motor just got put back together from a clutch problem. It did this before the rebuild and still dose it. It has new gas and plugs. Quote Link to comment Share on other sites More sharing options...
SyNtAxx Posted January 29, 2004 Report Share Posted January 29, 2004 Hey, is your compression low ? Nick Quote Link to comment Share on other sites More sharing options...
sredish Posted January 29, 2004 Report Share Posted January 29, 2004 What about your jetting? If its a little rich it won't want to start. I know someone mentioned the pilot jet. Also, what oil do you use. Castor oils (Castor 927) will seperate below 35 or so degrees and you will have a really rich mixture going to the motor when you start it cold. I know this personally, and I shake my machine before I start it in the winter. Not too mention, they will run a little richer in the winter anyway. So you could be borderline in the summer, but never notice, and when winter comes, its just enough. Try some BR8IEX NGK Iridium plugs (same as BR8ES, just Iridium version), the spark is a little hotter and that might help. Also, how is your overall ignition? You might have just enough power to keep it running, but low enough that its hard to get started. Just a thought. Scott Quote Link to comment Share on other sites More sharing options...
Nighty Posted January 29, 2004 Report Share Posted January 29, 2004 I was more thinking about a weak spark. a 96 shee.. it idles great.. dont see why it would be jetting or a choke tube. I say weak spark. Quote Link to comment Share on other sites More sharing options...
Nighty Posted January 29, 2004 Report Share Posted January 29, 2004 Oh sorry sredish, i missed your post during dinner I'm with ya about the ignition. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted January 29, 2004 Report Share Posted January 29, 2004 is your compression low ? Yeah....what's your compression looking like? Sounds like it could be bad gas too like fixitrod said too. Quote Link to comment Share on other sites More sharing options...
sredish Posted January 29, 2004 Report Share Posted January 29, 2004 Maybe it's time for an Adjust-on-the-fly ignition. I know I've been wanting to try one. Quote Link to comment Share on other sites More sharing options...
