runts Posted January 25, 2004 Report Share Posted January 25, 2004 Hey I know that this has been asked before but I want to know my top speed. What would you guys think??? Race cut plastics Bored .080 over Wiesco Pro lite piston Ported cylinders 34mm Keihin carbs Straight filters Carbon reeds Boost bottle Toomey T3 pipes and silencers 14/42 gearing 22" rear tires Quote Link to comment Share on other sites More sharing options...
superchicken Posted January 26, 2004 Report Share Posted January 26, 2004 how many stickers do you have? Quote Link to comment Share on other sites More sharing options...
kenr74 Posted January 26, 2004 Report Share Posted January 26, 2004 35 mph. 40 mph if you have a boost bottle. Quote Link to comment Share on other sites More sharing options...
runts Posted January 26, 2004 Author Report Share Posted January 26, 2004 Quit being a smart a$$ it will run over 40mph just sitting there. Quote Link to comment Share on other sites More sharing options...
ScreaminShee01 Posted January 27, 2004 Report Share Posted January 27, 2004 buy a gps and see Quote Link to comment Share on other sites More sharing options...
tithead Posted January 27, 2004 Report Share Posted January 27, 2004 im staying out of this 1 Quote Link to comment Share on other sites More sharing options...
runts Posted January 27, 2004 Author Report Share Posted January 27, 2004 I dont have the MONEY Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted January 27, 2004 Report Share Posted January 27, 2004 157.86mph according to my glyconium calculator Quote Link to comment Share on other sites More sharing options...
Big Blue Posted January 27, 2004 Report Share Posted January 27, 2004 to fast for me Quote Link to comment Share on other sites More sharing options...
rzcolobanshee Posted January 27, 2004 Report Share Posted January 27, 2004 Depends how high it will rev out, probably around 10,000 with t3's which would be 87 mph 8000 69.52480539 9000 78.21540606 10000 86.90600674 11000 95.59660741 Quote Link to comment Share on other sites More sharing options...
UpEnSmk420 Posted February 5, 2004 Report Share Posted February 5, 2004 157.86mph according to my glyconium calculator Erb. you have one of those things too??? Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted February 5, 2004 Report Share Posted February 5, 2004 yes i do:) Quote Link to comment Share on other sites More sharing options...
sredish Posted February 5, 2004 Report Share Posted February 5, 2004 Depends how high it will rev out, probably around 10,000 with t3's which would be 87 mph 8000 69.52480539 9000 78.21540606 10000 86.90600674 11000 95.59660741 Exactly what I got. If you stepped up to a 15 tooth front sprocket: 10,000 - 93 11,000 - 102.4 The 14 tooth setup is a 3.00 gear ratio The 15 tooth setup is a 2.80 gear ratio I'm running a 2.73 ratio currently. Quote Link to comment Share on other sites More sharing options...
flat track king Posted February 7, 2004 Report Share Posted February 7, 2004 8000 69.52480539 9000 78.21540606 10000 86.90600674 11000 95.59660741 ... this isnt EXACTLY true though, unless you have sum hiogh tech shit were u entered his mods b/c all those mods make a differance Quote Link to comment Share on other sites More sharing options...
sredish Posted February 7, 2004 Report Share Posted February 7, 2004 8000 69.52480539 9000 78.21540606 10000 86.90600674 11000 95.59660741 ... this isnt EXACTLY true though, unless you have sum hiogh tech shit were u entered his mods b/c all those mods make a differance Only gearing will tell you your top speed. Your mods only get you there faster, with one exception; mods that allow you to rev higher. If you have "x" front sprocket with "y" rear sprocket, and size "z" tires, they're only going to spin as fast as the motor with said gearing. Adding nitrous and big carbs and this and that, won't make the tires spin faster than the rear sprocket, which is as fast as the chain, which is only as fast as the front sprocket, which is only as fast as the motor. Like I said, with one exception, something, like a pipe, that will allow the motor to rev higher, which still follows the said gearing, but just allows the chain to turn faster. If I'm wrong, please correct me, and let me in on this science. Quote Link to comment Share on other sites More sharing options...
