Porting Idea
If you take the cylinders off your banshee you will notice that there are two cavities directly below the intake port in the top case. When the cylinders are in place these are just a traped air pocket that do nothing.
My idea is that you devcon these cavities up and drill 2 8mm(5/16) holes through them into the crankcase(one in each cavity). If the holes are drilled correctly they should have a nice smooth and straight entry from the bottom of the crankcase area. The reason i would devcon them up is to make it a perfect tube.
Next place the cylinders onto the top case and drill into the bottom of the intake track using the holes you have drilled through the top case. This will give you 2 matched ports from the crankcase area back into the inlet track.
My idea behind this is that it will allow a better flow and feed to the boost port. The intake charge will run through the piston windows as normal and swirl around the crancase. These ports(if drilled correctly) will be directly in the path of the air/fuel mixture as it rotates around the crankcase and help feed the boost port as they will shoot straight up to it and make it act more like a transfer port than a boost port.
I would like to here all views and comments antone has to say on this matter!
This has been done before on 250R's. The main problem with them is the reeds block the holes. Your better off doing boyesen ports and making sure you have everything working together.
