51222 Posted January 24, 2004 Report Share Posted January 24, 2004 hi what will be the best size for a piston if im gonna throw in my engine 4m stroker ?? Quote Link to comment Share on other sites More sharing options...
fixitrod Posted January 24, 2004 Report Share Posted January 24, 2004 Depends what you want. If your staying with stock sleeves, go as small as you can and save the bores. Not much if any by bumping just a couple sizes. If you are going balls out, drop some big bore sleeves in there. Quote Link to comment Share on other sites More sharing options...
51222 Posted January 24, 2004 Author Report Share Posted January 24, 2004 thanx man for the help... i think i wont go nuts i will stick to the small sleeves Quote Link to comment Share on other sites More sharing options...
fixitrod Posted January 24, 2004 Report Share Posted January 24, 2004 That's what I did. Just decide if you want a full ported motor $$$ or just matched ports. Matched port will keep a stock style timing and be cheaper. Good Luck Quote Link to comment Share on other sites More sharing options...
